Drifting after take off???
854 7 2017-6-12
chefdrew
Flight distance : 665554 ft
I am having an issue with the mavic drifting over past where I take off from thinking that the home point is over from where I take off.  Anyone else having the same issue or have any thoughts on what I need to change?  I calibrated the compass a few times and tried to repeat but still having the same issue,
2017-6-12
chefdrew
Here is a video of the issue...https://youtu.be/T855nNCfwS8
2017-6-12
VMav
Flight distance : 76814 ft
I don't know about internal algorithms used by DJI but common sense tells that because GPS can get you position  accuracy within 5-10 meters and you are probably 15 - 20 meters high so, might be video positioning does not working well at those conditions.
Try to hover at lower altitude and see if you have the same situation.  Or try to clean those two cameras at the bottom.
2017-6-12
Commodon
Flight distance : 347677 ft
if you are flying in GPS mode and you're experiencing drifting while hovering, then you need to recalibrate the IMU
2017-6-13
DJI Thor
Flight distance : 13602 ft
Hi chefdrew, like Commodon mentioned, do a IMU calibration, then try to fly it in an open area.
2017-6-14
chefdrew
Thanks all...i will keep it in mind.  I flew it twice yesterday and did not have an issue.hopefully wont happen again.
2017-6-14
chefdrew Posted at 2017-6-14 11:17
I hope so, too. Please keep us updated if you have any other problems.
2017-6-14
chefdrew
Well it did it again yesterday. Then,when I hit return to home, it returned to the spot where it drifted over to after takeoff.  It seems like the hme point ks being set a little away from where i actually take off from and the drone drifts over to that spot and hovers...
2017-6-15
