fans1c775817
Flight distance : 68694 ft
Brazil
DJI Wanda Posted at 5-5 02:28
Hello, there. We checked your video.
About the issue you feedback, please refresh the firmware of the aircraft and remote controller.
Then go outside and test the connection again.
Hi.
Yesterday I did all the refresh procedure to both drone and RC, via USB cable using the PC. Also reset RC and cleared drone data.
Today:
First flight outdoors away in a clear environment went well almost all time. Almost 1500m far and almost 500m high. However, when returning home, close to the RC it had signal failure again and right at end even lost connection.
https: //1drv.ms/v/s!Akir4hWP_IYBgb1LBNNILfA9COsBpQ?e=uDmcJj
Then I replaced the battery and flew a little more.
In the second video a flew more close to me and there were some signal interferences here and there, but there is nothing not even close to cause that.
https: //1drv.ms/v/s!Akir4hWP_IYBgb1Nu0TrMzGfhe52NQ?e=ljejaZ
In the third video you can see how often the RC loses connection and image just sitting right to the drone, some interferences and after the minute 2 it starts losing image:
https: //1drv.ms/v/s!Akir4hWP_IYBgb1KwTSOQa5WvCYzRw?e=YV7Ekw
And the fourth just to show the firmware versions that I forgot. Also, again losing completely the signal:
https: //1drv.ms/v/s!Akir4hWP_IYBgb1MjkcdkWVDZkTYaw?e=WxffMb
The drone is almost new but I already did a lot of flights just outside my house. This had never happened. Suddenly, right after the firmware update, this starts to happen.
Hope you can help me.
In case you need any logs, please show me how to get them.
Best Regards,
Guilherme
