Geo_Drone
Flight distance : 2733720 ft
Romania
FlyWithJudy Posted at 5-16 10:01
The issue for me is editing those 4k clips. I can't say that I have a bad PC but making travel video with color grade and very basic effects is pain in the butt at this point. Loading dynamic preview takes a lot of time and pre-rendering each sequence is annoying for me. Never had those issues with 2.7K footage from my Mini 2 and now with Air 3 it's just double the work time.
My friend, please tell me your computer configuration...I work in editing for a long time, also in computer hardware as I have a computer science graduation.
Will see if I can help you with an advice, as basic colorization and editing in 4K should work on any PC, even 6 years old ones, as long as you have a GPU that can process it.
Also depends on what you use, Filmora, CapCut, Premiere, Resolve....each one is using different things, for example Filmora, Capcut and Resolve last versions use Nvidia GPU and no need for CPU more than Intel I3....Premiere use more CPU than GPU, even in last version is not optimized for GPU only...
Of course, if you want a denoise, a Optical Flow with Warp, transitions 32 instead of 16, will kill your CPU also...but i think is not the case here.
Ask and will try to solve for 4K editing. |
