Michele_rm
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 888970 ft
DJI Paladin Posted at 11-22 19:26
Hi there. Thank you for reaching out. For example, when the DJI O3 air unit is successfully linked with the DJI Goggles 2, and switch the aircraft model to DJI Air 3 and then switched back to the DJI O3 Air unit, the DJI O3 air unit will be linked automatically. To switch between different aircraft models in DJI Goggles, open the goggles menu, select "Status", and then click the "Switch" button to switch between different models (note: when linking different aircraft, you need to switch to the corresponding aircraft model in goggles first). Hope this helps. Thank you.
It Works! Hope it doesn’t stop to get connected so fast with no binding necessary.
Really appreciate your comment, thank you very much.
M. |
