I am getting the above error, and can't correct it.
In settings, the instructions say to look down 60 degrees, look up, look down 90 degress then up.
When I do this nothing happens and I haev to reboot the goggles as I can't excit this screen.
Any ideas?
At 90 degrees downwards, it's best to bend down very far until it beeps. Then there will be 90 degrees left and right, ideally turning the whole body instead of just the head. it expects the 90 degrees pretty much right on point
djiuser_3aCG77NbJVg7 Posted at 5-4 22:55
I haven’t gotten this to work either. Do you look up 60 degrees until it beeps, then center etc? The on screen instructions says look up 60 then center then down 90 then center in one sentence.
djiuser_Mz4VfnqfBiHY Posted at 5-26 05:48
Yes, I followed the instructions carefully.
However, this happened on two sessions, but the error didn't appear the next two times I used it
ReproRetro Posted at 5-26 19:52
Similar experience. Just very occasional issue. Appeared again couple days ago when I launched in an area surrounded by high voltage electric fence that might have been activated and more or less under a power line. Electrical interference. No other system issue. Went ahead and had an uneventful session.
