TonyPHX
Flight distance : 11229610 ft
Suggestions:
If there is a SD card in the slot, remove it.
You have Assistant 2 for Consumer Series, so after installing that did you reboot the system? Do so if not yet.
Next, turn on the controller, then connect to the computer running Assistant 2. If it is not connecting, you may be hosed.
Try another wire, try another port, finally, try another computer. Barring any of that working, sounds like you need to move to plan B.
This is why I bring two drones to each job. 2 is 1 and 1 is none.
