Geo_Drone
Flight distance : 2733720 ft
Romania
LV_Forestry Posted at 5-20 04:10
At least we agree on that.
For the 2cm of accuracy, can you confirm that you are talking about absolute measurement on a 3D model or a Raster?
We have made for an oil company mapping at 50 km of pipes using Autel Evo 2 PRO and GCP's, without RTK. We also had Enterprise RTK but was not needed...
The number of drones used was 12, all with automated missions, just returning to base for changing batteries.
At generated map in Pix4D we had an error of 2 to max 3 cm after GCP corrections applied. GCP were applied on ground both left-right and fwd-bk each 100 meters, with a control distance of 2 meters each.
Elevation of ground was also corrected using 1 GCP at elevations that were more than 10 meters, using double pass at 85 degrees gimbal and 90 degrees gimbal.
Was a 2 month job including the Pix4D processing...
Now, with Air 3 I have tried for fun only to make a 3D photogram.model, using 2 GCP, horizontal and vertical, with waypoints and overlapping around 70%. After correction I had at one pension a measurement error of 8 cm to 10 cm, because overlapping was not enough and we have not used second pass on outer circle, as 3D models needs for precision...So I believe can be improved with slower speed for 85% overlap and a second pass with inclined gimbal at 45 degrees...
Was just for curiosity, to see if is able...it is, but the Geo coordinates have errors that are far from reality because GPS is not as precise as an Evo 2.
Another example:
Evo 2 Pro is able to replicate a mission with an error of 1 meter from designated path....
Air 3 had 5 attempts to replicate waypoints saved...all time errors were more than 4 meters, at one point we had almost 10 meters...all experiments made in same area with more than 20 sats strong signal.
Is all about how precise the GPS and computing is....For mapping, even a standard Autel E2P have one processing unit that is separate, only for autonomous flight, like M3 Ent have.
Hope to help you this infos.
Cheers. |
