Looking for a Lens Hood to prevent the shadow Flicker
7701 21 2014-9-17
jason_kimbrell
I've bought one on ebay, but was unhappy with the results.  You could see the hood from the gopro, and it didn't fit well because of the bar securing the camera to the gimbal.
Any recommendations?
2014-9-17
tony
Flight distance : 2856060 ft
Never thought about using a lens hood to prevent this. Sounds plausible. I am flying a P2V+ and would like info on a similar option for the stock camera. I'll have to do more research. Thanks for the heads up!
2014-9-17
jason_kimbrell
I've heard of people using gaffers tape over the lens, but I could never get the right size, and it falls off sometimes.
2014-9-17
screamtothex
I found this today.   DJI Phantom 2 Vision + lens hood
2014-9-17
jason_kimbrell
screamtothex@gm Posted at 2014-9-18 09:44
Thank you, I wonder if they have one for the Gopro also.
2014-9-17
screamtothex
Oh man there are tons of them GoPro Lens   I don't know if you have access to a 3D Printer, if not shapeways.com would print one really cheap
2014-9-19
fasterthaned
Flight distance : 569902 ft
If you are in the USA i can print you one and ship it to you..
2014-9-23
Tony
This isn't for the GoPro, but others coming to this thread with the P2V+ may be looking for the same thing. I've ordered this: http://www.ebay.com/itm/14140330 ... =p3984.m1497.l2649.    And will report back if it works or not. With the EBay Money Back Guarantee, it was worth a try. I think the key feature is that you can put the gimbal clamp on, without removing the lens hood. Fingers crossed it works....
2014-9-24
jason_kimbrell
fasterthaned Posted at 2014-9-24 05:12
Sure.  Can I paypal it to you?  I'd like 2.  How much, and has it been tested on a phantom 2 with a h3-3d?
2014-9-26
hd_ultra
You need to stay with black hoods. white is to reflective and will add more light to your camera.
2014-9-26
rongopro
best one is from viewkopter , so simple and cheap
2014-9-29
Tony
Got this one in the mail today (for the P2V+) from Ebay Seller Mr. Droneworx. It is pouring rain and I haven't had the chance to test it. But it looks promising.
2014-10-1
Tony
3D Printed, lightweight, and you can leave it on even when installing the gimble clamp and the lens cap. And the seller is top notch with extremely fast shipping.
2014-10-1
Tony
Profile. Fingers crossed, hope it works.
2014-10-1
nonrevs
These get very good reviews https://www.shapeways.com/model/ ... t-received&cr=3
2014-10-8
jason_kimbrell
Tony@CVP Posted at 2014-10-2 04:33
Tony, did you get good results?
2014-10-9
Tony
jason_kimbrell@ Posted at 2014-10-10 08:29
I meant to get back here and post results, sorry!
YES! The first one I ordered came in like 2 days. He ships USPS Priority, very fast! But it came damaged (happened during shipment). I told the seller on EBay and he promptly sent me another one, but he also sent 2 different betas that he designed, with a stronger type of plastic for his 3D printer. The one pictured is the beta he refers to as the "Duckbill". It works exactly as you would expect. I ran some tests on an extremely sunny day and flew the same pattern with and without the hood and I definitely saw shadow flicker without, and could not get any flicker once I put the hood on. Works Great!
I also noticed that it helps significantly at night with the red hue at the top of the image from the LEDs. I still get a slight red cast on the top of the images, but not nearly as much as without the hood.
Here is the seller info and the listing for the new "Duckbill" which I just noticed is out of beta and now available:
http://www.ebay.com/itm/Camera-D ... hash=item20eddda67e
This product works, it is extremely lightweight, you can put the gimble lock and lens protector on and not have to remove the hood, and the seller has great customer service and fast shipping. It's a solid buy in my opinion.
2014-10-10
jason_kimbrell
Tony@CVP Posted at 2014-10-10 21:55
YES! The first one I ordered came in like 2 day ...
Thank you.  That is very helpful.
2014-10-17
noctividus
My company produced a bunch of lens hoods to deal with the problem. We're selling them now:
http://apolloairobotic.com/products/lenshood/
It's a simple and effective solution.
2014-11-4
vonbaron1
Flight distance : 42014 ft
noctividus@gmai Posted at 2014-11-5 04:38
http:// ...
I tried the Airobotic lens hood and when in flight with my hex, it would flip my GoPro up now and then on the gimbal.  Took it off and the problem went away.  Sure would like to use it but not if its doing that.
2014-12-31
legacy.4
hey make one out of duck tape it works.
2015-1-12
noctividus
vonbaron1 Posted at 2015-1-1 09:46
I tried the Airobotic lens hood and when in flight with my hex, it would flip my GoPro up now and  ...
Sorry it didn't work for you. Since you said "hex" I imagine you're not using a Phantom 2. These hoods haven't been tested on anything but the Phantom 2 with a Zenmuse gimbal.  It's really not a solution that works on any other platform.
2015-4-3
