New DJI LiDAR Range Finder (RS) Firmware Released (04/09/2024)
9091 5 2022-9-20
DJI Support
Flight distance : 2408 ft
Overview:
  • Date:2024.04.09
  • Firmware:v00.00.00.52
  • DJI Assistant 2 (Ronin Series):v2.1.11
What’s New?
  • Added autofocus when using grip with DJI RS Focus Motor (2022) and DJI LiDAR Range Finder (RS).
  • Fixed issue: Tap to focus was not working in spot mode.
Notes:
  • Connect the USB-C port of the DJI LiDAR Range Finder (RS) to the computer and update firmware via DJI Assistant 2 (Ronin Series). Do not disconnect the DJI LiDAR Range Finder (RS) from the computer during the update.
  • If the firmware update fails, restart DJI LiDAR Range Finder (RS) and retry.
Overview:
  • Date: 2023.05.16
  • Firmware: v00.00.00.50
  • DJI Assistant 2 (Ronin Series) V2.1.7
What’s New?
  • Added support for recognizing and focusing on cars. The focus range is 1.5 m to 7 m. Note ActiveTrack is unavailable when tracking cars.
  • Added support when using autofocus without calibration with a lens that is registered via the Ronin app using RS 3 Pro. Requires Ronin app firmware v1.6.6 or above and RS 3 Pro firmware v01.04.00.00 or above.
  • Added support for using autofocus, waveform, etc, after connecting DJI LiDAR Range Finder and DJI Transmission using the DJI LiDAR Range Finder (RS) to DJI Transmission Cable Hub. Requires DJI LiDAR Range Finder firmware v00.00.00.50 or above, DJI Transmission firmware v01.05.0400 or above, DJI High-Bright Remote Monitor firmware 01.05.0400.
  • Improved the autofocus speed for DJI LiDAR Range Finder (RS). The fastest speed is now up to twice.
Notes:
Overview
  • Date: 2022.09.20
  • Firmware: v00.00.00.39
  • DJI Assistant 2 (Ronin Series) V2.1.4
What’s New?
  • Added support for DZOFILM Vespid Cyber Cine lens without lens calibration.
  • Added support for autofocus when using 2x zoom.
  • Optimized ActiveTrack performance.
Notes:
2022-9-20
Frontliner 2020
Philippines
thank you for sharing these info...
2022-9-20
Fred Fred Fred
Flight distance : 4512966 ft
Thanks for the info.
2022-9-20
djiuser_9ZmY3jj6TXNr
Ecuador
How can I restart LiDAR?
2022-12-16
djiuser_uXU2TmzlIsuI
Please provide download link to the app "DJI Assistant 2 (Ronin Series) V2.1.4"
2023-3-1
djiuser_uXU2TmzlIsuI Posted at 2023-3-1 11:44
Hi, djiuser_uXU2TmzlIsuI. Thank you for reaching out. May we ask why you need the DJI Assistant 2 (Ronin Series) V2.1.4? The current DJI Assistant 2 (Ronin Series) is V2.1.11. Which can be downloaded from this link.
5-2 23:01
