How to remove big Red sign Goggles dynamic.... Solved
916 18 4-18 23:56
alex_markov
Flight distance : 40068986 ft
Bulgaria
Since the beginning, despite having done all the updates in my goggles there is a big red message (see below) Goggles dynamic...
Please tell me how to remove it???
PS
Found it in the menu about download from the aircraft!!!
4-18 23:56
Thats the fly safe database update thats needed
4-19 02:05
PS did you figure out the arrow in the box as I dont have that with mine.
4-19 02:06
alex_markov
Bulgaria
DAFlys Posted at 4-19 02:06
No I have no idea what this is
4-19 02:39
wizlord
Flight distance : 99921 ft
Hello, can you please tell me where did you go to do the update  because I have this problem since this morning and all firmwares are up to date …
4-20 10:21
alex_markov
Bulgaria
wizlord Posted at 4-20 10:21
Аs I explained in the first post - menu - About - search for dynamic... with no version (others have) and click on it it'll propose to download from aircraft (Avata should be powered) and that's it!
4-20 12:09
wizlord
alex_markov Posted at 4-20 12:09
Thanks for the response, but I am still confused as new to avata , I am doing it from goggle or from dji fly app ?
4-20 12:46
flojo
Flight distance : 42175 ft
wizlord Posted at 4-20 12:46
In the Googles. I had the same issue today after the firmware update. In the goggles I clicked on it in the menu as described in the post above, then it was still there but as soon as I went out of the menu it disappeared. Maybe wait an additional second or two. It should work.
4-20 13:45
Nelsonlee
Flight distance : 2779203 ft
Malaysia
Just connect your Avata 2 to DJI Assistant 2 (Consumer Drones Series) update the FLY SAFE DATABASE.
4-20 20:27
Hi there. We're glad you already managed to fix it. Your update will help other users who may encounter this. If it still fails to update the FlySafe database we suggest updating or refreshing the firmware using the DJI Assistant 2. Have a great day ahead.
4-20 21:37
wizlord
Thank you all for your responses! I appreciate it !
4-21 12:00
DJI Wanda
Hello, there. After confirmation with our engineers, the arrow represents the aircraft, which indicates the heading direction of the aircraft. It is the positioning display of aircraft in European areas.
4-29 01:27
DJI Wanda Posted at 4-29 01:27
Hi Wanda,  do you know if that can be turned on outside the Eu like in the UK?
4-29 02:23
bighi
Flight distance : 47455053 ft
I would like to know how to turn that positioning indication off.
4-29 02:29
DJI Wanda
DAFlys Posted at 4-29 02:23
Hi, this arrow only occurs in European areas.
4-29 02:36
Info
Flight distance : 136998 ft
Same problem: the database is not loaded into the goggles 3
Please help me:  the goggles says:
- go to settings (in goggles)
- about to update
In about there is nothing to click on! How can I download this database? Already put the Avata to the app to update fly database, but how is this coming into the goggles?
4-30 09:53
Info
DJI Tony Posted at 4-20 21:37
Hi there. We're glad you already managed to fix it. Your update will help other users who may encounter this. Changing the WiFi network or using a smartphone hotspot to update might also help. If it still fails to update the FlySafe database we suggest updating or refreshing the firmware using the DJI Assistant 2. Have a great day ahead.
It did not work, can you help me?
4-30 11:02
Info@oranjestate.nl Posted at 4-30 11:02
Hi there. Thank you for reaching out. This problem only occurs in the EU area. Please try to manually update the dynamic database. The specific method is: open the menu in the goggles and select "Settings" - "About" - scroll down to see the dynamic safety data and click "Check for updates".
Note: There is no need to connect to a mobile phone. The update must be done in the goggles instead of the App.
Please keep us posted. Have a nice day.
5-1 03:08
djiuser_VA3EMtXtGEIL
I have the same problem. When I open "About" in "Goggles 3", I only see the serial number of all devices and the battery's charge cycles. I can't find "update" anywhere.
I have tried using "DJI Assistant 2 FPV", where I can't see anything. I can't connect the drone to the program at all.
I have also tried to update the "Fly Safe Database" via "DJI Fly". It says that I already have the latest software.
Now I'm out of ideas
5-31 01:59
