Attention: Buggy RTH function !?!
363 7 4-27 00:20
AlSo-Fotografie
Flight distance : 545820 ft
Buggy RTH-function?
I didnt test myself, but here is a experience from a guy on youtube.
His drone reduces the altitude while it returns via RTH. Caused by lost signal.
He forced it by turning of the fpv controller.
4-27 00:20
fichek
Flight distance : 1036263 ft
Croatia
Is this some kind of a troll video or do you not realise your throttle is below mid and therefore in N mode that makes it go down? Nothing to see here
4-27 01:04
Thanks for sharing. .  something to be aware of for sure.
4-27 01:05
The Saint
Flight distance : 6260171 ft
I believe there are some interesting comments in the video discussing this.  I can't offer much but I can say this:  I see no value in a "FailSafe RTH" that slowly descends in altitude because of the stick location.  I can understand if the pilot moved the stick after the "Failsafe RTH" is triggered and the process took the input.  Picture this:  You drop your RC off a small ledge and it hit the ground just out of reach and the stick is lowered.  Your drone will probably crash coming back home, no?
DJI has been known to ignore the sticks when you hit pause and you have to repeatedly give it some juice before it decides to respond.  For RTH home, maybe they can ignore the stick unless you really want to descend like that and you move the sticks *after* the re-connect.
4-27 07:21
Thank you for reaching out. I have already forwarded this to the relevant team to check. I will keep you updated. Thank you for your patience.
4-28 02:31
Hi, Thank you for patiently waiting. It was confirmed that it was an issue with the user not returning the stick to the center as mentioned by ficheck. The designated team will then decide whether to add a prompt or other optimization based on the user's suggestions. Have a nice day.
4-28 19:37
fichek
Croatia
DJI Tony Posted at 4-28 19:37
Hi Tony. Thanks for confirming this, I think some people just need to read the user manual and/or apply common sense
4-30 02:31
fichek Posted at 4-30 02:31
Hello, fichek. No problem. We’re always here to provide clarification, address concerns, and offer assistance. You may also contact us for any concerns. Best regards!
5-1 02:44
