120km already on the Avata 2.
697 39 5-1 04:19
120km already on the Avata 2, and loving every minute of it,    how are you all getting on with clocking up the flight distance?
5-1 04:19
A J
Flight distance : 14754314 ft
Impressive distance DA
5-1 06:34
Visual Air
Flight distance : 2710115 ft
Hi DA
Mine shows zero kms and zero flight hours. I have only had the opportunity to put one flight on my Avata 2 due to windy rainy weather. It still should have shown my first flight?
5-1 06:55
A J Posted at 5-1 06:34
Thanks AJ,  it would have been more but chores and the weather get in the way.
5-1 07:16
Visual Air Posted at 5-1 06:55
Hi DA
Have you plugged your goggles into your phone so that it can sync your distance.
5-1 07:17
SurveyorDJI
Flight distance : 1811549 ft
By comparison, my drone's at 96 miles
5-1 08:39
Visual Air
DAFlys Posted at 5-1 07:17
Thanks.
I did not do that, thanks for the tip I will give it a try.
5-1 09:29
Dirty Bird
Flight distance : 41442379 ft
Hi DA
You have to connect the Goggles 3 to your phone via USB, with Fly running, in order to upload the logs to your account.
5-1 12:27
Visual Air
Dirty Bird Posted at 5-1 12:27
Thanks Dirty Bird..
5-1 12:50
TonyPHX
Flight distance : 11229610 ft
You are way ahead!  I just got the lenses from Honsvr the other day.  Awaiting my case from GPC before I take it to the airfield to rip a few.
5-1 17:04
SurveyorDJI Posted at 5-1 08:39
How did you get it to display miles?  Mines already in imperial and shows MPH but only KM in the flight logs.
5-1 20:38
TonyPHX Posted at 5-1 17:04
I went for the DJI Goggles ruck sack and I have to say Im loving it,  and I can easily pop a mini drone and batteries in there too.
5-1 20:38
SurveyorDJI
DAFlys Posted at 5-1 20:38
I don't even know how, just playing with settings. But the logs still say km
5-1 20:59
Visual Air Posted at 5-1 09:29
Thanks.
If you ever want to use Find my drone then you also have to do that first as the find my drone only works on the phone.
5-1 21:02
Visual Air
DAFlys Posted at 5-1 21:02
Thanks good to know.
5-2 08:15
Dirty Bird
Wow you went all in.  I love the GPC cases but they are so overpriced.  $249 for the Avata 2.  I've been picking up the hard cases from FPVTosky for my Minis or Lykus for the original Avata,  For the Avata 2 I am leaning towards one of the choices below:
STARTRC Avata 2 Hard Case - $93.99
FPVTosky Semi-Hard Avata 2 Case - $59.99
5-2 08:56
OldGuy2024
Flight distance : 632428 ft
IIRC, have flown 19 batteries.  But the DJI Fly app last recorded data when I was setting up the hardware. Did get around after my 8th battery to activate Sync on the app.  Thought needed to Sync to collect data and get rid of a glitch in the "Fine My Drone" feature.  Still no flight data.  Now I know why?
I probably should read the users Manuals from start to finish.
So technically right now the app shows 38 minutes, 3.32km, 5 flights.  Shortest flight  0km and 1 min. Longest flight 94 meters and 16 minutes.   Not very much for 19 batteries.
5-2 10:07
Dirty Bird
OldGuy2024 Posted at 5-2 10:07
That would explain it!  It would be nice if you could setup a direct Wifi connection for the goggles that would sync flight records & check for updates directly.
5-2 10:40
OldGuy2024
Noticed on the iPhone, Setting>DJI Fly App>option to allow the app to access Local Network was not activated. Just activated it, but no request for network password.  Assuming connected.  Do have WiFi signal from where I usually set up the landing pad.   Completed the sync via USB cable.  Bit slow to download the flights not synced. My max upload speed in 750kbs and download speed is 8mbs.   Had the time.  Retired. Busy work done for the day.  Raining.
5-2 11:09
OldGuy2024 Posted at 5-2 11:09
Sadly you need to connect with a cable to sync the logs.
5-2 20:10
TonyPHX
Dirty Bird Posted at 5-2 08:56
Well, I like my GPC cases.  They are well built, cleverly designed, and honestly, it just feels better for me.  But that having been said, any case is better than no case.  I just feel more organized when I have a place for everything and everything it it's place.  : )
5-5 16:02
That is impressive!
5-16 22:04
Im at 300km now.
5-16 22:24
I already suspected something like that
5-16 22:25
Montfrooij Posted at 5-16 22:25
Actually I think it 294km but close enough,  and almost all of that was on the same day as mine cant seem to keep the date/time for more that a blink of the eye.
5-16 23:03
DAFlys Posted at 5-16 23:03
Oh wow. That is weird. Or is that a common issue too?
5-16 23:09
Montfrooij Posted at 5-16 23:09
A few mentions here and Ive got DJI to confirm they know of an issue,  but when you script copying the last days of footage from the memory card it really messes you up,  and then for a second time editing.
5-16 23:12
DAFlys Posted at 5-16 23:12
Yeah, my script would not like it I guess.
5-16 23:13
Montfrooij Posted at 5-16 23:13
It also doenst help the Avata as they use the newer naming convention,  so ranther than DJI_XXXX.mp4 they now get a name like DJI_20240510171851_0066_D.mp4
5-16 23:18
DAFlys Posted at 5-16 23:18
Oh no. Not at all!
5-16 23:19
yogi053
Flight distance : 26104915 ft
How? Just how do you find the time to fly so much? I think you've cloned yourself 3 or 4 times over! I'm retired, but cannot match anything like your time in the air.
5-16 23:44
OldGuy2024
Someone likes to fly. Retired and I'm not even close to 100km based on the DJI Fly app.  I do like to sail, windsurf, windfoil.  But those activities all require at least F4 winds and I prefer to fly quads in lighter sustained winds.  So there goes that excuse.
Why is it the "Flight distance:" is noted in ft v. kilometers?  USA, Liberia, and I think Burma are the remaining nations that are not really metric.  '83 Metric Conversion Act and we still use Imperial.  Ben Franklin, Thomas Jefferson, John Adams.... all proponents of the metric system.  +200 years later.....
5-17 10:59
yogi053 Posted at 5-16 23:44
Sorry Yogi. I cant even say In trying to fly this one a lot,   Im currently in the Lake District and so many places its just not an appropriate place to fly it,
5-17 21:07
OldGuy2024 Posted at 5-17 10:59
The forum has been stuck on ft for as long as I've been here, but then we get a bigger number in ft vs Km.
5-17 21:36
OldGuy2024
Finally broke the 100km mark. But our differential is growing.
5-20 10:10
OldGuy2024 Posted at 5-20 10:10
I’ve been away so I’m only at 322km
5-20 10:16
frankymusik
Flight distance : 27904331 ft
DAFlys Posted at 5-20 10:16
...is that really your only goal?
Do you always want to be the "furthest"...?
5-21 04:41
frankymusik Posted at 5-21 04:41
Not my only goal but Im interest to see if other people are actually flying their products.
5-21 06:18
OldGuy2024
DAFlys Posted at 5-21 06:18
Ditto.  First UAS of any form owned that keeps record of distance.  Usually land with +30% capacity. Guessing km total would be little higher, but unwilling to stress the battery or put myself in another oh poo moment.
Didn't even realize until one day when flying the trail system on the property the Avata2 calculates when RTH Low Battery engages.  Had +30% capacity, but apparently too far from Home.  Probably would have RTH ascended right into an overhanging tree branch or two.  Disengaged the RTH. Landed. Took a hike.
Side note: The black/grey color scheme makes it a difficult quad to find in the woods. Without the ESC beeper activated I would have been looking for the quad maybe still today.  Wouldn't be the first loss quad.  Find My Drone and loud ESC beeper.  Two more +s for the Avata2.  Picked up some spare after-market cloned propellers. Bright orange. Might help.  But a bit concerned regarding quality of generic, no name propeller from AMZ sellers.  DJI, Blaze Orange colored propellers please.  Sort of match the gimbal mount trim.
5-21 10:43
OldGuy2024 Posted at 5-21 10:43
I wont use non OEM props,    technically here they would count as a non standard modification as they are not OEM approved so would change the place where you could fly.     But you are right DJI need to make a selection of coloured props,   Id love orange to match like you.
5-22 00:00
