jphughan
DJI Gamora Posted at 5-1 22:12
Hi, jphughan. Thank you for reaching out. Please enable the Camera view recording function.
[view_image]
Once this function is turned on, the video recorded by the Goggles will also have an OSD, and the WiFi-shared image transmission to the mobile phone will also have an OSD. If this function is turned off, there will be no OSD in the video recorded by the flight goggles or in the WiFi-shared image transmission screen. Please note that the video captured by the aircraft will not have an OSD in any case.
Hi DJI Gamora,
Thank you for the reply, but as I have said multiple times in this thread already, the behavior you are describing for how those settings work does not match what is actually happening with my Avata 2 and Goggkes 3.
Based on replies from other users, the behavior you describe may be the way it is INTENDED to work, and possibly the way it DOES work on other drones and/or Goggles models, but on my Avata 2 and Goggles 3 with current firmware as of this writing, the Camera View Recording setting works very differently.
I would appreciate it if you or someone else at DJI could test that setting for yourself specifically with an Avata 2 and Goggles 3 in order to reproduce this issue I am reporting. |
