fichek
Flight distance : 959892 ft
Croatia
You need to make sure you know the correct uart where TX/RX from O3AU are connected to your flight controller, then go into presets in Betaflight Configurator (if you bought a BNF drone, it's probably in your manual, otherwise look for manual of your flight controller), find one for DJI 03 (use the search bar). Before applying the preset, chose the correct port number and then go into OSD tab and configure as you like, it should start appearing right away if your quad is powered on (but you can do it with it powered off to prevent overheating while you set things up). |
