DJI Tony
djiuser_OU6h4sP3L53L Posted at 7-24 04:18
I was flying my dji air s2 which is not registered but as I was flying it about 136 meters my controller suddenly shuts off. I know the controller was fully charged, long story short drone self landed and is fine but now my controller won't turn on anymore. Is it possible the fda shut my controller off or did it just stop working. I haven't flown it that many times so idk what happened.
Hi there. I'm sorry for the experience. Can you please try the steps below:
1. Please make sure that it's being powered on the correct way. Press the Power Button for one second, then again, hold it to power the remote controller on.
2. Please press the power button once to check if the battery level LEDs are light on. If not, please charge the remote controller and then try it again. If the remote controller cannot be charged, please replace the charger if possible. If it still can not work, please send back the remote controller.
3. If the battery level LEDs are on, please try to connect the charger, then power on the remote controller to see if it is normal, if not, please send back the remote controller for testing. To submit a repair request please use the following link: https://repair.dji.com/us/repair/index. Hopefully, this helps and I hope you don't need to send the remote controller for repair. Thank you for your understanding and patience. Have a great day ahead. |
