fansba3b7009
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
Flight distance : 314908 ft
Austria
ok so I figured it out...you need to connect it like in the video... bind to the transmission system transmitter first and switch on gyroscope control, then directly connect to the I3 , then it works as long as you dont switch off the high bright monitor...if you switch on and off only the stick on the left handgrip works and no more gyro
I actually do like the settings its on , no sensitivity, no dead-end, perfect speed (same angle on monitor and on gimbal ,1 to 1)
please DJI , please support this, it sort of works allready , but of course not with rebinding all the time
but gyroscope control is much better for a lot of people, especially if you are used to it
I control the 4d and the ronin 2 and 3 always with the gyro of the high bright monitor this and Idont want to go back on the I3 and use sticks, this is a 100% dealbreaker for me and the main reason I got the I3
thanks! |
