DJI Gamora
Afarkas Posted at 5-3 07:37
Hi, no i dont need industry-level high precision. Im just seeking for what conditions i can give to m4p to get the best out of it - just get the best m4p can do if have the ideal conditions.Thanks
HI, Afarkas. The waypoints in a waypoint flight task are recorded based on the GPS positioning information. The GPS positioning accuracy will be affected due to external factors such as errors in satellite signal reception and environmental interference. Therefore, when you perform a waypoint flight task based on a previously saved flight route, there might be flight route differences between the current and previous tasks.
It is recommended that you perform a waypoint flight task based on a previously saved flight route when sufficient GPS satellites can be found. To minimize the flight route difference between two waypoint flight tasks, we recommend that you perform the two tasks within a short period of time. You can also perform post-editing to reduce the differences in the generated videos. Thank you for your understanding. |
