DadDog
Flight distance : 2907 ft
According to the manual there are 3 types of RTH. Smart RTH (manually push the button), Low battery RTH, and Failsafe RTH (loss of controller signal).
The 20m radius is mentioned under the Failsafe only.
The way the manual reads is that the 20m radius scenario does not apply to Smart RTH or Low Battery RTH.
However the 20m altitude scenario does (phantom4 pg15).
The way I read it is if you are under 20m altitude and any of the three RTH's are triggered, it will first climb to 20m not the preset Failsafe altitude.
I thought it would climb to the preset altitude, so I must interpret this as if you're inside the 20m radius that it will climb to 20m altitude.
The manual is very ambiguous and confusing in certain areas.
You must read, then go into a big field and interpret what you have read.
Better yet, how about dji make RTH more simple;
When engaged, it will ascend (if below) to the preset Failsafe altitude, or maintain current altitude (if above the preset) and fly to the home point and ascend to the ground.
Change software to remove all 20m radius and 20m altitude restrictions.
Update the manual. |
