JustName
Flight distance : 1420705 ft
MarcoR Posted at 11-22 04:24
Good method, however just bring all the body to a temperature of 70/80 degrees withut the battery inside, no component will damage that temperature.
If it is epoxy glue anyway it will tend to crumble even when heated, so in my opinion better to unscrew the lens group totally, clean the sensor and glue residue, reassemble everything by putting some glue like Bostik or similar.
Better to proceed anyway if you also consider the potential damage to the cam, maybe with Care Refresh you are better off.
In my opinion this is too much action for a small rotation.
This is also NOT epoxy glue. Calibration by using an iPad is possible, but you will still have to make some pics and compare them on a big display, because the preview in the dji mimo app is not good enough. |
