IftiBashir
Posted in another thread on the same topic, but will post here also.....
Cameras are not designed to purposefully produce heat. This is a natural occurrence due to the power of these small chipsets being placed in a tight physical frame. Its inevitable and affects not only the Pocket 3, but also action camera manufacturers, such as GoPro. If you want ridiculously high shooting settings like 4K/60 and 4K/120 from a tiny gadget, then you have to expect the heat to go along with it. I do not understand how you can possibly imagine 'the product could have been designed so it would not get hot at all'? That's simply impossible. Heat will ALWAYS be generated when pushing power from these tiny chipsets. The problem comes down to how you manage heat dissipation, which is difficult when it comes to a tight physical frame, again, as we see with all action camera designs. If you want something so small, but so powerful, then its just part of the parcel I'm afraid.
Should you have to accept it? No, you shouldn't. The camera should record lengthy sessions as advertised, although you may have to do it at lower settings where less heat is generated in the first instance, so less heat to dissipate. If you think a firmware update will fix this issue, it wont. They cant just magically make the camera produce less heat, or make it dissipate that heat any quicker - its down to the laws of physics. All you can do is add airflow in order to aid that heat dissipation somewhat.
What they did with the Action 2 was introduce a case so it didn't 'feel' as hot and burn your fingers in the first place. That doesn't fix the issue, its a workaround.
Similarly, GoPro's attempt to combat heat was to introduce a new 'tripod mode', which would be used with no airflow, and would simply reduce capture settings enough so that the heat threshold wasn't hit in the first instance. Again, not a fix for overheating, just a workaround.
Sorry to be the bearer of bad news, but if you are waiting for a firmware update to 'fix' this, then it won't come. Can DJI do it? Yes, they can. It's clear they can since non EU models do not seem to suffer as much. Will they do it? No they won't, because they are bound to EU laws and have no say in the matter. The only option for now is to try to work around the issue as much as possible by introducing airflow as and where you can (which I appreciate isn't as easy with a handheld camera as it is with an action camera), or lower you settings for lengthy recording sessions to reduce heat generation in the first instance. It all comes down to how users intend to use their camera, which is why I stated I will use it as normal to see how it works for my own personal intended usage - if it's not suitable it'll simply be returned, or a warranty claim placed. Unfortunately, we have no other choice.
What would be nice is if DJI actually came clean and confirmed the operating temp threshold for EU activated models. Saves us all the guesswork. But I suspect they won't. This will just be swept under the carpet, since the majority of Pocket 3 users probably don't even know there is any overhetaing issue in the first place. We on this forum represent a tiny fraction of the user base for this product after all. |
