Geo_Drone
Flight distance : 2676129 ft
Romania
Aavis Posted at 11-8 22:17
No but when requirements are met then yes:
"Measured with the touchscreen turned off and Wi-Fi disabled, in a windless environment at a room temperature of 25 ℃, when recording 4K videos at 60 fps".
Welcome to forum.
Some people here have some benefits that works in background, they will always troll people if they post an issue. Get used with it, I am for now.
Check how Hallmark activated himself after my post, without mentioning him or other...he felt his guilt and started to scream TROLL, like the thefts that start screaming THIEF when they are caught.
The fact is simple: In Europe some OP3 works and some does not...There are 2 factors that make the difference:
1. The ambient temp when operating it
2. The assembly quality and radiator mount inside OP3.
I must admit I have seen at a friend one unit working with same settings up to 35 minutes in 4K 60 until started Overheat message....after this, was unable to start it for 5 minutes, each start giving in less then 1 minute OVERHEAT message. Only after cooling down a little was able to start again.
The one I have tested (YES, DAVID, is not in my list YET, as that 2 x AIR 3 appeared 2 months after activation, one not even now is shown in list) was overheating fast...Yes, the crack file works, but is pushing the OP3 temp to a very high limit...
As for Mini 3 Pro, between launch and +6 months after, DJI changed thousands, until they applied the method I sent them, to fill the chamber with rubber...Yes, David, was sent by our dev team, after we have dismounted and tested it...So try to slow your horses, as you are a noob in this.
Cheers. |
