External HDMI Recorder
1960 8 2015-3-27
kelleyre
Flight distance : 90833 ft
If I were to use an external HDMI recorder (Atomos Ninja 2 or better) that has a better bit rate than the inspire at 60mbp would the video be any better, (not thats its bad , I was just curious)
I read in one of the forums some where that the HDMI out was 1080P, and the output to the ipad using the usb cable was 720P.
Thanks
2015-3-27
kelleyre
I am hoping that the HDMI output on the controller could be able to output 1080P at 30 and 60 fps.
2015-3-27
Marktho1
Not sure on that but even so wouldn't you also be recording any signal losses or lag during flight?
2015-3-27
kelleyre
Probably
I was just curious if it would look better    (less artifacts)
Again
Thanks
2015-3-27
kelleyre
Anybody have any ideas
2015-3-27
Marktho1
I can run a test on it tomorrow with my Ninja and let you know but honestly I doubt it...
2015-3-27
doctrrf
I think you're stuck with 720p on the HDMI out. Here's a couple samples recorded on a Ninja Star.
The camera's SD card is the best way to go.
2015-3-27
Marktho1
Yea I just hooked up the ninja to test it out. 720p output.
2015-3-27
kelleyre
Darn I was so hoping for 1080p
2015-3-27
