Charissa
Flight distance : 689334 ft
South Africa
Suren Posted at 11-25 05:25
The DJI Configs file mod will work on both Android and iOS. The maximum power at which consumer products can transmit on the 2.4Ghz wifi frequency used by DJI aircraft is 0.1 watts (0.1W) in many countries. In a minority of countries, including the U.S. it is 1W. Some countries lie in between. Only one country, India, allows more than 1W (In India, the max is 4W!). In most parts of the world DJI aircraft uses a power output of 0.1W by default, which is pretty weak. In the U.S., it uses 0.4W. However, the equipment can be configured to a maximum of 1.5 Watts of TX power anywhere in the world with the directions below. In transmission setting, if you look at the signal graph, you can see than there is two horizontal lines, one for the “~1km” and one for the “~4km”.
If you are in EC mode, the “~1km” line is just under 90 dbm/mhz, so between 90 and 100dbm/mhz and the “~4km” line is between 100 and 110 dbm/mhz. If you are in FCC mode, the “~1km” line is between 80 and 90 dbm/mhz and the “~4km” line is juste upper 100 dbm/mhz, so between 90 and 100dbm/mhz.
You lost me anyway there M8.
Comming from the Air, so far, around 2kms, would be scary enought as is, so I will practice first.
Why don,t you get a friend to go to a beach about 8 or 10 or so kms away, get the gps, and send your drone there, land, and he can bring it back? Just head in a straight line there. Let us know, could maybe be a new world record.
I was using the fake gps thing for the air, could never get the hack to work. Maybe should give it a tr;y again. Does the two versions of DJI go install side to side? |
