JohnDG
Flight distance : 1097270 ft
Malaysia
Hi Nick,
I guess you have the right firmware already on your Smart Controller as you were able to fly the Mini 2 with it.
In priciple the Fly app should give you the same options on the SC as you were using on your smart phone. Same app, only different device. So, you should be able to find the same options at the same places.
However, as Monkey007 stated, the firmware released in July '21 has been installed with the version of Fly that has been used in that period. The SC is an android device. If you're using an Apple smart phone, I don't know if some things might look different in the app.
You can also check the version of Fly. DJI made moved some of the options or redesigned them over the versions. Check on "settings" and scroll down on the left part of the screen to see the version number.
You can use the browser on the sc to download the latest version of Fly from the DJI web site and install it on the SC (if you didn't get the message to upgrade). Be aware that in the latest version of Fly 1.4.12 (1430) the color of the frontled can't be set and the reset to default function of the gimbal doesn't seem to work. |
