Quaxo76
Flight distance : 479386 ft
Hello, I've been using my drone for some photogrammetry work. This means covering an area while taking LOTS of straight-down pictures (as in, way more than one thousand).
When downloading the pictures to the PC using the SD card, I see that the drone makes several folders under DCIM on the SD card, named 100MEDIA, then 101MEDIA, 102MEDIA and so on. Inside each folder, the photos are stored as DJI_xxxx.JPG with xxxx being a number from 0001 to 0999.
But this means that in different folders, there are repeated filenames. And when I try to copy the pictures onto a single folder on my PC (because the project needs all pictures in one folder) there are conflicting names.
I know I can use a batch renamer to just add a date/time tag to the name, or something like that, but this is inconvenient.
Is it possible to have the drone just store all the pictures in a single folder, with unique filenames? Or even if it has to split them into several folders, is there a way to just have them have unique names? My phone just names them with a date/time tag, and it works very well, also for sorting them. Is it possible at all?
Thank you
Cristian
