At first I want to watch what I shot with my Mini 3 on my TV. Even though I fly with the DJI RC and I can connect the RC to my smart TV but still can NOT view what I see on the RC on the connected TV (Samsung Series 7...).
So the next thing I can think of is using the "Screen Mirroring" on my iPhone. I then install the DJI Fly onto my iPhone and of course in order to see the file I have to turn on the Mini 3 and connected to my iPhone. This works fine but I hate to keep the Mini 3 on because of the heat issue which prompt me to place the Mini 3 in front of the AC for cooling.
Next I decided to get the lightening to SD card reader so that I can download the file from the Mini 3 to my iPhone by pulling out the card thus no need to leave the Mini 3 turned on. I bought 2 lightening to SD card readers, one of which is the knock off at $8.00 and the Apple one at $30.00. Well,.... neither work except the still photos. Once I click import, the progress wheel will keep spinning up to about 25% then stop there and moment later the RED exclamation mark shows up. I tired to do it 1 clip at a time as well as several clips at a time, still no go. I decide to return the 2 adapters but Amazon would NOT accept the real Apple one for refund but in stead connected me to an Apple rep to see if the unit is actually defective. I ended up with the Apple top tier tech support after the first one couldn't figure out the problem. I told her what was not working and she said that she could help. About 5 minutes later, she decided to ask me if she can use the "Screen Mirror" on my iPhone so that she could see exactly what happened. She promised that she could only use her cursor to move around my screen to guide me BUT she wouldn't be able to execute anything. We spent a good 1/2 hours doing: Wi-Fi reset, system screen refresh, disable cellular data, check the cloud storage integrity, flush the default Import folder and redirect to the new Test folder, etc. NO GO!!! No choice so she had to create the so called "Open case ticket" which I can show to Amazon to get my refund.
Now, I copy the SD card from my Mini 3 onto my solid state flash drive to see if I can play the video back on my PC. Again, it will only playback the MOV file but the MP4 ones are blackout! Next I use the SD card adapter (the one that you can insert the micro one into it) plugged directly onto my PC USB port, still no go either. I then tried with my new laptop but to no avail. Next, I copy the files to my PC hard drive, still the same result i.e. playable only the MOV format ones. Lastly, I connect my Mini 3 to my PC with the USB to C cable and ......SAME result!!
Whenever, I clicked to play the MP4 file, it would freeze and the error says, "Server execution failed". Also some members mentioned that my display/system can NOT handle the 4K video, which is not the case.
Someone suggested that I should turn the Cine Mode OFF which did NOT solve the problems.
Again, all I want is to be able to watch my clips on TV without leaving the Mini 3 turned on in front of my AC all the time.
Any suggestion will be appreciated.
