This is the second time this has occured. Exposure was locked. A dark band appears on the left side of the frame and the exposure is shifted (even though locked).
I was in manual mode as well. It occurs in just one frame.
Is this a software issue or a hardware issue?
Edit: It occurs during the following simple manuever. Normal Mode: Moving the drone backwards with the camera pointed back at the subject with the sky about 1/3 of the top of the frame. It's very obvious in 4k
DowntownRDB Posted at 7-17 04:53
It's a bit hard to see in the video but easier to see on the still. Not the expert but seems more like a software issue.
I feel like it's a software issue as well. I'm gong to try to replicate it in both portrait and landscape modes.
fans7ac73174 Posted at 7-18 07:39
Def a flash frame of some sort. A shadow wouldn't be as defined. And its repeatable in different locations with different lighting
Ok, thanks, was just an idea, hope you get it sorted
