JACOB1995GGG
Flight distance : 1503822 ft
Denmark
Sean-bumble-bee Posted at 7-18 01:16
If you want different 'darknesses' in front of each lens how would you suggest they manufacture them? I can think of 3 methods.
1) One filter of NDx then the other filter of NDa or NDb or NDc or NDd or............ pre-mounted in a housing that is similar to the existing one but that would lead to the need to manufacture a vast range of filters of high price.
2) Glass built in to the filter housing for one camera then removable glass for the other camera, removable glass is a common feature with 'proper' camera filters e.g. Lee filters, but I can imagine it being difficult to change the glass with the filter housing fitted to the camera and, due to the probable small size, tricky with the filter housing removed from the camera.
This is the backside of the DJI filters. To me it looks like the filter is glued onto the frame.
The way I see it, you could approach it in two ways and both would be more expensive than the current one yes. (But IMO worth it):
You could have two separate pieces of glass and glue them on with the available space from the current frame. Fx. Nd 4 for tele and 32 for main or ND8 for tele and 64 for main.
2.
You could use a single gradient filter (of course with the correct strengths as listed before), and mount exactly as DJI is currently doing it.
Just my two cents. I would happily pay more for this feature.
BR
Jacob |
