fansfbd2311f
Flight distance : 384698 ft
I realize that the documentation says that you can store the batteries in the charging hub (not sure if it says you can leave a battery in the drone), but the batteries are supposed to self discharge a bit after a day, and more so after five days. I have noticed that the batteries are not self discharging, or at least it's not indicating any level of discharge on the charging hub when I press the button on the hub.
So, what are you all doing with your batteries? Removing them from the hub and drone when not in use? The case that I am using doesn't have enough room to pull the batteries out of the hub enough to disconnect them. Seems like the batteries should be "intelligent" enough to know to self discharge regardless of where they are at the time.
Your thoughts?
(Edit: after re-reading the battery section of the manual, I realize that it's nine days before it self discharges to 60%, not five. I believe my batteries have been in the charging hub for seven days undisturbed, so I'll give it a few more days and report back)
