BarnSwallow
Flight distance : 5076896 ft
DJI Paladin Posted at 11-16 21:56
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please confirm if the aircraft does the same issue when used at normal temperature? In addition, we do not recommend flying the aircraft below 0°C to avoid this issue. Thank you for your understanding and support.
I can occur if you fly in sport mode, or if you don't have an ND filter. The cold weather I think is a new issue with the drone. I could hear a grinding noise when it landed, as the gimble tilted up. Perhaps I just have a failing gimble. I set up a repair request, and I'll send it in. (I did do a calibration of the gimble, didn't help). |
