djiuser_fzs5m3VOoABS
Flight distance : 1939455 ft
British Virgin Islands
Good Morning All,
I would really appreciate some help understanding what I am doing wrong.. Just bought the Mavic 3 Classic (M3C) with the RC Controller - Grey controller with built in screen.
When I was first turning things on - loggin in, updating firmware etc, I saw that the controller connected to the drone and there was a live camera feed. I changed the battery and tried to connect the controller and M3C and nothing was working. When I was asked to put the drone into paring mode, I would click "Pair" and a little pop up would say "Ensure the aircraft is powered on and in paring mode". Which it was. What was strange is when I clicked 'Pair' it would do the classic faded grey button with a 1 minute count down. Not sure why. The controller's firmware is up to date. I have downloaded the assistant and downgraded to both previous updates and both of those don't work either. I am currently doing another downgrade and seeing what happens.. Again..
I used an older controller for my Air 2S to connect to the M3C and that worked. I was able to get the drone up and was wondful. What a quiet drone! Also shows that it is a controller issue, not drone. I am currently doing an aircraft update using the old controller and seeing if that might help the connection between the M3C and the new controller.
On the new controller I have done hard reset, factory reset, left it overnight, all batteries 100% both drone and controller.
I am not sure what else to do... I would really appreciate some help.
Thank you.
