HerkMan
Hey all. I've scoured the forum, youtube, and the internet in general so I'm not too hopeful on being able to resolve this but here goes.
I recently replaced the ribbon cable on the camera and gimbal on my P2V+. After replacing the cable I powered up and I'm getting "Slow Blink" on the camera LED (0.2s on, 1.8s off) which indicates a CMOS Sensor Error.
I've tried to update the camera firmware by loading the "firmware_plus_v1.3.0g.bin" file onto a clean SD card (renamed as "firmware_plus.bin") and this hasn't done anything. When I power up the Phantom with the SD card in the camera I just continue to get the CMOS Sensor Error and when I check the file on the SD card it has not changed to the ...bak00 extension like it should if the firmware loads.
The only thing I haven't done is the hard reset of the Phantom itself by jumping the lower F1 and F2 pins on the controller inside. But I'm not sure that is really what is needed given the problem I'm experiencing.
I have the current firmware loaded in the Phantom using the Phantom 2 Vision+ Assistant Software v3.8.
The P2V+ flies just fine, with or without the camera on it. But the camera will not link up with my iPhone.
Any ideas?
