Hello,
I have noticed that recently my DJI Mini SE is unstable when flying. Even in open places where there is almost no wind. I leave it without moving it while in the air, but it looks quite unstable, you could say it looks like it's shaking and it doesn't stay static as it should. So in the videos of the drone, you can notice that it is shaking and you can not record good videos because of the instability. I have already calibrated the compass and the IMU, but without any improvement. Please help me to have stability again when flying my drone.
*]:w-6 [&>*]:h-6 text-deepl-blue active:text-blue-chill active:bg-dark-8 enabled:hover-capable:hover:bg-dark-8 dark:enabled:hover-capable:hover:bg-dark-2 disabled:text-dark-5 disabled:cursor-default button--1bU-y" aria-describedby="deepl-ui-tooltip-id-126" style="border-width: 0px; border-style: solid; border-color: currentcolor; --tw-border-spacing-x: 0; --tw-border-spacing-y: 0; --tw-translate-x: 0; --tw-translate-y: 0; --tw-rotate: 0; --tw-skew-x: 0; --tw-skew-y: 0; --tw-scale-x: 1; --tw-scale-y: 1; --tw-pan-x: ; --tw-pan-y: ; --tw-pinch-zoom: ; --tw-scroll-snap-strictness: proximity; --tw-gradient-from-position: ; --tw-gradient-via-position: ; --tw-gradient-to-position: ; --tw-ordinal: ; --tw-slashed-zero: ; --tw-numeric-figure: ; --tw-numeric-spacing: ; --tw-numeric-fraction: ; --tw-ring-inset: ; --tw-ring-offset-width: 0px; --tw-ring-offset-color: #fff; --tw-ring-color: rgb(0 125 178 / 0.5); --tw-ring-offset-shadow: 0 0 #0000; --tw-ring-shadow: 0 0 #0000; --tw-shadow: 0 0 #0000; --tw-shadow-colored: 0 0 #0000; --tw-blur: ; --tw-brightness: ; --tw-contrast: ; --tw-grayscale: ; --tw-hue-rotate: ; --tw-invert: ; --tw-saturate: ; --tw-sepia: ; --tw-drop-shadow: ; --tw-backdrop-blur: ; --tw-backdrop-brightness: ; --tw-backdrop-contrast: ; --tw-backdrop-grayscale: ; --tw-backdrop-hue-rotate: ; --tw-backdrop-invert: ; --tw-backdrop-opacity: ; --tw-backdrop-saturate: ; --tw-backdrop-sepia: ; font-family: -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Helvetica, Arial, sans-serif; font-feature-settings: inherit; font-variation-settings: inherit; font-size: 20px; font-weight: 400; line-height: inherit; padding: 0.5rem; appearance: button; background-image: none; cursor: pointer; height: 2.5rem; width: 2.5rem; border-radius: 0.25rem; --tw-text-opacity: 1; transition: opacity 300ms ease-in-out 0s, background-color 250ms ease-out 0s;">*]:w-6 [&>*]:h-6 text-deepl-blue active:text-blue-chill active:bg-dark-8 enabled:hover-capable:hover:bg-dark-8 dark:enabled:hover-capable:hover:bg-dark-2 disabled:text-dark-5 disabled:cursor-default button--1bU-y" aria-describedby="deepl-ui-tooltip-id-128" style="border-width: 0px; border-style: solid; border-color: currentcolor; --tw-border-spacing-x: 0; --tw-border-spacing-y: 0; --tw-translate-x: 0; --tw-translate-y: 0; --tw-rotate: 0; --tw-skew-x: 0; --tw-skew-y: 0; --tw-scale-x: 1; --tw-scale-y: 1; --tw-pan-x: ; --tw-pan-y: ; --tw-pinch-zoom: ; --tw-scroll-snap-strictness: proximity; --tw-gradient-from-position: ; --tw-gradient-via-position: ; --tw-gradient-to-position: ; --tw-ordinal: ; --tw-slashed-zero: ; --tw-numeric-figure: ; --tw-numeric-spacing: ; --tw-numeric-fraction: ; --tw-ring-inset: ; --tw-ring-offset-width: 0px; --tw-ring-offset-color: #fff; --tw-ring-color: rgb(0 125 178 / 0.5); --tw-ring-offset-shadow: 0 0 #0000; --tw-ring-shadow: 0 0 #0000; --tw-shadow: 0 0 #0000; --tw-shadow-colored: 0 0 #0000; --tw-blur: ; --tw-brightness: ; --tw-contrast: ; --tw-grayscale: ; --tw-hue-rotate: ; --tw-invert: ; --tw-saturate: ; --tw-sepia: ; --tw-drop-shadow: ; --tw-backdrop-blur: ; --tw-backdrop-brightness: ; --tw-backdrop-contrast: ; --tw-backdrop-grayscale: ; --tw-backdrop-hue-rotate: ; --tw-backdrop-invert: ; --tw-backdrop-opacity: ; --tw-backdrop-saturate: ; --tw-backdrop-sepia: ; font-family: -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Helvetica, Arial, sans-serif; font-feature-settings: inherit; font-variation-settings: inherit; font-size: 20px; font-weight: 400; line-height: inherit; padding: 0.5rem; appearance: button; background-image: none; cursor: pointer; height: 2.5rem; width: 2.5rem; border-radius: 0.25rem; --tw-text-opacity: 1; transition: opacity 300ms ease-in-out 0s, background-color 250ms ease-out 0s;">
*]:w-6 [&>*]:h-6 text-deepl-blue active:text-blue-chill active:bg-dark-8 enabled:hover-capable:hover:bg-dark-8 dark:enabled:hover-capable:hover:bg-dark-2 disabled:text-dark-5 disabled:cursor-default" aria-describedby="deepl-ui-tooltip-id-106" style="border-width: 0px; border-style: solid; border-color: currentcolor; --tw-border-spacing-x: 0; --tw-border-spacing-y: 0; --tw-translate-x: 0; --tw-translate-y: 0; --tw-rotate: 0; --tw-skew-x: 0; --tw-skew-y: 0; --tw-scale-x: 1; --tw-scale-y: 1; --tw-pan-x: ; --tw-pan-y: ; --tw-pinch-zoom: ; --tw-scroll-snap-strictness: proximity; --tw-gradient-from-position: ; --tw-gradient-via-position: ; --tw-gradient-to-position: ; --tw-ordinal: ; --tw-slashed-zero: ; --tw-numeric-figure: ; --tw-numeric-spacing: ; --tw-numeric-fraction: ; --tw-ring-inset: ; --tw-ring-offset-width: 0px; --tw-ring-offset-color: #fff; --tw-ring-color: rgb(0 125 178 / 0.5); --tw-ring-offset-shadow: 0 0 #0000; --tw-ring-shadow: 0 0 #0000; --tw-shadow: 0 0 #0000; --tw-shadow-colored: 0 0 #0000; --tw-blur: ; --tw-brightness: ; --tw-contrast: ; --tw-grayscale: ; --tw-hue-rotate: ; --tw-invert: ; --tw-saturate: ; --tw-sepia: ; --tw-drop-shadow: ; --tw-backdrop-blur: ; --tw-backdrop-brightness: ; --tw-backdrop-contrast: ; --tw-backdrop-grayscale: ; --tw-backdrop-hue-rotate: ; --tw-backdrop-invert: ; --tw-backdrop-opacity: ; --tw-backdrop-saturate: ; --tw-backdrop-sepia: ; font-family: -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Helvetica, Arial, sans-serif; font-feature-settings: inherit; font-variation-settings: inherit; font-size: 20px; font-weight: 400; line-height: inherit; padding: 0.5rem; appearance: button; background-image: none; cursor: pointer; height: 2.5rem; width: 2.5rem; border-radius: 0.25rem; --tw-text-opacity: 1;">*]:w-6 [&>*]:h-6 text-deepl-blue active:text-blue-chill active:bg-dark-8 enabled:hover-capable:hover:bg-dark-8 dark:enabled:hover-capable:hover:bg-dark-2 disabled:text-dark-5 disabled:cursor-default" data-testid="translator-target-toolbar-copy" aria-describedby="deepl-ui-tooltip-id-62" style="border-width: 0px; border-style: solid; border-color: currentcolor; --tw-border-spacing-x: 0; --tw-border-spacing-y: 0; --tw-translate-x: 0; --tw-translate-y: 0; --tw-rotate: 0; --tw-skew-x: 0; --tw-skew-y: 0; --tw-scale-x: 1; --tw-scale-y: 1; --tw-pan-x: ; --tw-pan-y: ; --tw-pinch-zoom: ; --tw-scroll-snap-strictness: proximity; --tw-gradient-from-position: ; --tw-gradient-via-position: ; --tw-gradient-to-position: ; --tw-ordinal: ; --tw-slashed-zero: ; --tw-numeric-figure: ; --tw-numeric-spacing: ; --tw-numeric-fraction: ; --tw-ring-inset: ; --tw-ring-offset-width: 0px; --tw-ring-offset-color: #fff; --tw-ring-color: rgb(0 125 178 / 0.5); --tw-ring-offset-shadow: 0 0 #0000; --tw-ring-shadow: 0 0 #0000; --tw-shadow: 0 0 #0000; --tw-shadow-colored: 0 0 #0000; --tw-blur: ; --tw-brightness: ; --tw-contrast: ; --tw-grayscale: ; --tw-hue-rotate: ; --tw-invert: ; --tw-saturate: ; --tw-sepia: ; --tw-drop-shadow: ; --tw-backdrop-blur: ; --tw-backdrop-brightness: ; --tw-backdrop-contrast: ; --tw-backdrop-grayscale: ; --tw-backdrop-hue-rotate: ; --tw-backdrop-invert: ; --tw-backdrop-opacity: ; --tw-backdrop-saturate: ; --tw-backdrop-sepia: ; font-family: -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Helvetica, Arial, sans-serif; font-feature-settings: inherit; font-variation-settings: inherit; font-size: 20px; font-weight: 400; line-height: inherit; padding: 0.5rem; appearance: button; background-image: none; cursor: pointer; height: 2.5rem; width: 2.5rem; border-radius: 0.25rem; --tw-text-opacity: 1;">
*]:w-6 [&>*]:h-6 text-deepl-blue active:text-blue-chill active:bg-dark-8 enabled:hover-capable:hover:bg-dark-8 dark:enabled:hover-capable:hover:bg-dark-2 disabled:text-dark-5 disabled:cursor-default" data-testid="translator-target-toolbar-share" aria-describedby="deepl-ui-tooltip-id-68" aria-expanded="false" data-headlessui-state="" type="button" id="headlessui-popover-button-12" style="border-width: 0px; border-style: solid; border-color: currentcolor; --tw-border-spacing-x: 0; --tw-border-spacing-y: 0; --tw-translate-x: 0; --tw-translate-y: 0; --tw-rotate: 0; --tw-skew-x: 0; --tw-skew-y: 0; --tw-scale-x: 1; --tw-scale-y: 1; --tw-pan-x: ; --tw-pan-y: ; --tw-pinch-zoom: ; --tw-scroll-snap-strictness: proximity; --tw-gradient-from-position: ; --tw-gradient-via-position: ; --tw-gradient-to-position: ; --tw-ordinal: ; --tw-slashed-zero: ; --tw-numeric-figure: ; --tw-numeric-spacing: ; --tw-numeric-fraction: ; --tw-ring-inset: ; --tw-ring-offset-width: 0px; --tw-ring-offset-color: #fff; --tw-ring-color: rgb(0 125 178 / 0.5); --tw-ring-offset-shadow: 0 0 #0000; --tw-ring-shadow: 0 0 #0000; --tw-shadow: 0 0 #0000; --tw-shadow-colored: 0 0 #0000; --tw-blur: ; --tw-brightness: ; --tw-contrast: ; --tw-grayscale: ; --tw-hue-rotate: ; --tw-invert: ; --tw-saturate: ; --tw-sepia: ; --tw-drop-shadow: ; --tw-backdrop-blur: ; --tw-backdrop-brightness: ; --tw-backdrop-contrast: ; --tw-backdrop-grayscale: ; --tw-backdrop-hue-rotate: ; --tw-backdrop-invert: ; --tw-backdrop-opacity: ; --tw-backdrop-saturate: ; --tw-backdrop-sepia: ; font-family: -apple-system, BlinkMacSystemFont, "Segoe UI", Roboto, Helvetica, Arial, sans-serif; font-feature-settings: inherit; font-variation-settings: inherit; font-size: 20px; font-weight: 400; line-height: inherit; padding: 0.5rem; appearance: button; background-image: none; cursor: pointer; height: 2.5rem; width: 2.5rem; border-radius: 0.25rem; --tw-text-opacity: 1;">
[color=rgb(255 255 255 / var(--tw-text-opacity))][backcolor=rgb(15 43 70 / var(--tw-bg-opacity))]
