Problem bip esc and drone disconnected from remote control
676 18 2023-9-11
Lahatra2392
Flight distance : 24573 ft
Madagascar
Hello everybody..I am new to the group and I would like to ask for your help..
I have a mavic pro 1 which i hadn't used for a month.. i had used it a few days ago, and during the first vertical flight, everything went well.. but after i control before I could make my second flight, suddenly, the drone disconnected from the remote control, and there was the beep of the esc when it was turned on.. and now, I can no longer manage to connect me to the drone on the remote control.. Is there anyone who has already had this problem please?
I found this video on youtube, it represents exactly the same situation as my drone
Thanks for your help
2023-9-11
DJI Tony
Hello there. Sorry about the experience. May I know what error message are you getting from your screen? I appreciate your patience.
2023-9-11
Lahatra2392
Madagascar
DJI Tony Posted at 9-11 01:12
Thank you for your response
I cannot see any error message on my phone and on my remote control because the drone and the remote control can no longer connect.. I have not yet tried to connect it to dji assistant. .
2023-9-11
DJI Tony
Lahatra2392 Posted at 9-11 02:14
I see. Can you please try the steps below:
1. Please check whether the aircraft and remote controller both are powered on. Press the power button once, press it again, and hold to power on the device. The device will beep when it is powered on successfully.
2. Please check whether the aircraft has a microSD card. If yes, remove the microSD card and try linking again.
3. Please switch the linking method between linking with the app to linking with combination buttons. From the RC please press C1 Button + C2 Button + Video Recording Button + Shutter Button
4. If the issue still persists, check whether the remote controller has been updated to the latest version. Connect the remote controller to the app. After the connection is successful, check whether there is a prompt to update the firmware. If yes, update the firmware to the latest version and try linking again.
5. Please connect the aircraft to the computer, check the aircraft firmware version in the DJI Assistant 2, and try linking after updating and refreshing the aircraft’s firmware to the latest version. You can download the correct version here: https://www.dji.com/global/downloads/products/mavic
6. If the issue persists, please record a video showing the linking process and firmware version screenshot and we will check it for you. Thank you for your cooperation. Have a great day ahead.
2023-9-11
Lahatra2392
Madagascar
DJI Tony Posted at 9-11 02:32
Thanks for the instructions and for your help.
I have already tried steps 1 and 2, but no connection between the remote control and the aircraft.
I will follow steps 3 to 5 and I will send you a video and a screenshot of the firmware version.
Thank you for your help and have a great day too
2023-9-11
DJI Tony
Lahatra2392 Posted at 9-11 02:44
Thank you very much and you are most welcome. Please keep us posted.
2023-9-11
Lahatra2392
Madagascar
DJI Tony Posted at 9-11 02:46
Thank you, and I'll let you know
2023-9-11
Lahatra2392
Madagascar
hello... so, I tried step 3 but it didn't work.. The same for steps 4 and 5. I put a screenshot of the firmware versions of the remote control and the drone below
2023-9-11
Mobilehomer
Flight distance : 18150351 ft
Try reverting to 400 on both.
2023-9-11
Lahatra2392
Madagascar
Mobilehomer Posted at 9-11 10:15
ok, I'll try that.. thanks
2023-9-11
Lahatra2392
Madagascar
hello... I tried to downgrade the firmware version, on the drone and the remote control, but still the same result. The status led indicator wiwch does not light up normally..
2023-9-11
DJI Tony
Lahatra2392 Posted at 9-11 22:44
Hi there. Will you be able to show us a video of the operation showing the issue? We appreciate your patience.
2023-9-12
Lahatra2392
Madagascar
DJI Tony Posted at 9-12 02:30
okay, just a moment
2023-9-12
Lahatra2392
Madagascar
https://youtu.be/IbEjLe15YkE?feature=shared
2023-9-12
DJI Tony
Lahatra2392 Posted at 9-12 11:14
Hi there. Please make sure to follow the steps from the following video:
If the issue still persists, I'm afraid you need to send the drone for repair. You can also get assistance with DJI support by visiting this link: https://www.dji.com/global/support. Thank you for your patience and understanding have a great day ahead.
2023-9-12
Lahatra2392
Madagascar
DJI Tony Posted at 9-12 19:29
https://www.youtube.com/watch?v=G52F4hlR4MA
Hello..
thank you for the video..
I followed the video, and the camera is the only one viewed in the dji go 4 application... the status of the drone in the application is "disconnected"... and the drone still cannot connect on the remote control..
Actually, I think it is a hardware problem because when starting up, the red lights on the front arms do not light up, and the status indicator light on the back remains permanently green at low brightness than its normal brightness.. I don't know if it's the power board that is dead?
2023-9-12
Hamid Blogger
Pakistan
Hey there! Sorry to hear about your issue. To help you out, we'll need more details. Are there any error messages you're seeing? Also, check your drone's firmware and remote control connection. Sometimes a firmware update can resolve such problems. Keep us posted!
2023-9-13
DJI Tony
Lahatra2392 Posted at 9-12 19:53
Hello..
Hi. If the issue still persists after the troubleshooting. We suggest sending the drone for repair. You can also get assistance with DJI support by visiting this link: https://www.dji.com/global/support. Thank you for your patience and understanding have a great day ahead.
2023-9-13
Lahatra2392
Madagascar
Hello...I replaced the esc power board and the drone connected again to the remote control and everything seems to be working normally..Thank you very much for your help, because it allowed me to know other things like firmware updates for my aircraft. have a nice days..
2023-9-14
