DJI Susan
djiuser_elmIyQiglT87 Posted at 10-21 04:01
What im saying is that make atti mode to disable vertical pozitioning not just horizontal, because a faulty barometer can cause a flyaway and the drone thinks its falling, and because of that it goes into the sky over the 500m limit
Your feedback will be noted. In Attitude mode, the drone’s attitude will be stabilized, but the drone’s position and flight speed cannot be controlled by the aircraft, yet, the pilot can still use the controller to land the drone as soon as possible as Wanda mentioned.
Regarding your feedback about the low battery settings, we are afraid we can not consider your suggestion, because if the drone is already in critical low battery mode, that means the current battery level is only sufficient to support the drone to land, if the landing stops and the battery runs out mid-flight, the drone will drop from the sky, that would be dangerous.
As additional information to you, the pilot can still control the aircraft in critical low-battery landing, you can push the stick to control the altitude and direction of the aircraft and try to find the nearest location to land the drone, however, as mentioned, if the drone runs out of its battery mid-flight, the drone will shut off and drop off from the sky. Thank you for your attention. |
