DJI Wanda
olivier97911 Posted at 10-24 17:36
yes, the drone controller can in fact connect to the software and update firmware. how ever the drone won't even get past the waiting for usb insert, I have timed it correctly and done it many times. I've restarted my pc and reinstalled the software
drone also does a long flash of green and then long flash of red.
If the aircraft status indicators are solid red, we recommend you send it back for diagnosis.
About the DJI Assistant2, make sure you download the right version:
https://dl.djicdn.com/downloads/ ... Manual_v1.2_enI.pdf
Please check whether the drone can be recognized by the drone first.
If possible, please change a computer, USB cables or USB ports to cross-test.
If the issue persists, please send the aircraft back for diagnosis.
Here is the link: https://www.dji.com/support/repair?from=store_homepage |
