First FULL Manual (Acro) Flights with Avata 2
1950 12 2024-5-10
A J
Flight distance : 15283773 ft
Two of the same video - one from the Goggles 3 (1080p) showing flight info without stabilisation (below) and one from the Avata 2 (4K/30 rendered to 1080P) with EIS (Rocksteady3) which I've added to works/nature section as the videos were playing together on the same upload.
ND16 used
First time doing full manual with manual flips and spins - this was anything but 'easy acro' when the drone is flying at 45mph lol. Cruising at over 50mph was also a lot of fun and even touched on 60MPH. Did three flights in full manual today with no crashes and hardly used pause. It is all starting to click after just a handful of manual flights and some sim work. I think the real difficulty here is when you fly low - that will take some serious practice over time but pleased I am now finally flying without the training wheels on!
2024-5-10
Visual Air
Flight distance : 2710115 ft
Nice flight. I have a hard time getting used to manual flight.
2024-5-10
A J
Visual Air Posted at 5-10 07:51
I had a few moments for sure lol - high altitude flying (200 to 400' AGL) at first makes it a lot easier as does practicing on a sim. I will find it very hard at low altitude - I'll switch to n/s mode when flying low I think (for now)
2024-5-10
DAFlys
Nice one AJ,  and congrats on the roll.
2024-5-10
A J
DAFlys Posted at 5-10 19:52
Cheers DA
2024-5-10
Suren
Flight distance : 13728120 ft
New Zealand
Nice flying Aj. Those rolls will make me sick if I had to do them.
2024-5-11
A J
Suren Posted at 5-11 22:12
They took my breath away mate - never did it before and wasn't certain what to expect. Half expected to fall out the sky. If you end the flip pointing downward (in a split second) the drone will dive to the ground so you need to be high up to compensate or have your rates tuned perfectly for your skills to end the flip in a perfect 360 rotation to the horizon. You literally control everything in full manual: throttle, pitch, yaw and roll to determine speed, altitude, direction and rotation all of which require constant micro adjustment while the drone is flying at up to 60mph. Not to mention wearing goggles too. I am very pleased with how my maiden acro flights went overall - great start to proper FPV as seen so many crash at this stage. It is a lot harder than it looks.
2024-5-11
Dronep
Flight distance : 802021 ft
Austria
Congratulations, it really looks easy when someone else doing those tricks. Happy and safe flying.
2024-5-16
A J
Dronep Posted at 5-16 00:00
It actually is quite easy but equally nerve racking - even now I still think the drone will fall.
2024-5-16
Dronep
A J Posted at 5-16 00:18
Never been in FPV world and I'm still wondering should i jump in and if yes what should be my first drone. All seems to be so fragile.
2024-5-16
A J
Dronep Posted at 5-16 21:49
Only you can decide that but I have no regrets is going down this route myself!
The Avata 2 is the only FPV drone I have ever flown and probably the best to learn on due to all of the safety features such as pause button/air brake, RTH etc They are also the least fragile of DJI drones.
2024-5-16
Dronep
A J Posted at 5-16 22:34
Thank you and happy flying.
2024-5-16
A J
Dronep Posted at 5-16 22:54
You're welcome
2024-5-17
