After completing video shooting and returning to its original position, the Drone turns to the left. This is noticeable when choosing a distance of 50m. This happens if the object is a Person. If you select an area, the problem is not reproduced.
The video shows how the Drone behaves at 30m and 50m. The problem is at the end of the videos.
And this happens on both cameras. This problem was not noticed with other modes.
Now I have updated the Drone firmware again.
Hi there. Thank you for the information provided and we're sorry for the trouble. We may need to coordinate this to our relevant team for further clarification. I will keep you posted.
The turns are not present at me...so...try to update the FW and also take a full calibration of COLD IMU and Compass, to see if is still doing this.
Make sure you use Cold calibration of IMU.
I ran the tests again. The problem is with the 1x camera, the drone can even turn 180 degrees. With the 3x camera there is no problem, or deviations during return are insignificant.
