Terra 4.X: Importing, Matching and Evaluating GCPs in Lidar Point Cloud Reconstruction Missions (M300 RTK mission, RTK Fix, Zenmuse L1, Terra V4.X, 6 GCPs measured with Emlid RX)
Hello Everyone! Since we don't come from the “surveying” field, we have the following questions that we can't really answer. who can help?
Since Terra V3.9, the import of elevation control points for lidar point cloud reconstruction is supported & accuracy control is carried out. A.): Can this be controlled by matching, similar to photogrammetry? Or does the software optimize this internally and the deviation is only visible afterwards? B.): The Terra V3.9 notes say: "When importing elevation control points for LiDAR point cloud missions, the output coordinate system and vertical coordinate system must be set to default." What means standard: Our “standard coordinate settings” regarding coordinate system and reference height (analogous to the Emlid RX) or the default value in Terra software (WGS84 & Default)??
Even though this is of course a point cloud, we assumed that we could "control" the accuracy with the GCPs. Or does DJI Terra not offer this in this form and we have to carry out the comparison with measured GCPs using third-party software (like TerraSolid)? Our main problem in understanding is that we lack an overview of the deviation of the L1 point cloud mission with measured GCPs. Thank you for attempting to explain! Kind regards Tim
