Geo_Drone
![](https://forum44.djicdn.com/data/attachment/common/c8/common_2_usergroup_icon.png) Core User of DJI
Flight distance : 2733720 ft
Romania
fans7b376bd2 Posted at 6-17 23:05
Ugh. Now this kind of details, I LIKE!
Yea, makes sense, I saw that sensors feed and it looks at least challenging for object recognition, but I thought maybe is just the way the feed is shown in the app, reducing streaming rate.
Lidar processing in real time at a speed of 30km/h in follow is not possible to be put on such small drone, as is a high consumer and also heavy on a rotating turret.
What Autel did better was to put 2 sensors on each side, creating a 3D real vision in the Evo2Pro consumer drones, thing that made possible to see a lot better the obstacles....the problem was the software that was years behind DJI, but hardware even now is better than DJI.
You do not have many options when you need light, not very consuming avoidance system...omni cameras are the best choice at this point and the current tech, but if you look at Skydio 2 omni and at DJI omni, you will realize what means Nvidia and high res sensors....but...a lot of consumption in power....
I have a lot of drones, but I have never tested the follow me as I flight manual mode all time, only once I have tried that Mastershots and my heart stopped as the drone was going to a white wall in full speed...managed to stop it and never needed again....
Also because the sensors works in processing image not all time, but only the ones that are on direction that is moving, if the drone is changing path quickly is no time to process the images from the sensor on that new path in first second, so if is at full speed you will probably get a crush even if is a large tree.
The point of OA is to warn you first if you miss something, not to avoid all time all obstacles, and many people expect to buy a drone that is fully autonomous....is not... |
