How to disable beginner mode in the Avata 2
2278 6 2024-6-18
fansb1cf5046
Flight distance : 516447 ft
Hi,
How can I deactivate the Avata 2 beginner mode?
When I activate Manual mode, the first flight is limited in speed while the next two flights I do have all the power of the engines.
According to the user manual, I must deactivate the beginner mode in configuration>control>beginner mode. However, that option does not appear to me. Attached screenshot.
Thank you.
2024-6-18
DJI Thor
Flight distance : 13602 ft
Hi there, thank you for reaching out. Please connect the aircraft and retry, thanks.
2024-6-19
fansb1cf5046
I just connected the Avata 2 by cable:
1. To the glasses and nothing happens.
2. to the mobile and DJI Fly App and nothing new appears either.
I have also turned it off and on again and the beginner mode section does not appear either.
2024-6-19
DJI Thor
fansb1cf5046 Posted at 6-19 00:52
May I know if you also connect the DJI RC Motion 3 together?
2024-6-19
fansb1cf5046
No, I dont have the Motion controller. I sold it because I use the Controller 3. I’ll try to get one to check it whit it paired.
2024-6-19
fansb1cf5046
Solved. Once I connect the motion controller the beginner mode swicht has appeared. I dissabled it. Is it permanent?
2024-6-19
DJI Natalia
fansb1cf5046 Posted at 6-19 09:33
Thank you for informing us that the problem has been fixed. The solution is permanent, but if you want to turn on the mode again, you will need to use the Fly app to do so.
2024-6-19
