Osmo Action 4 vs DJI Mic 2 auto-reconnecting issue after update
847 4 2024-7-28
Minh88Vlog
Vietnam
Hello, I have updated latest firmware for my Osmo Action 4 and DJI Mic 2. Then, they have stopped auto-reconnecting if I turn off and turn on one of them. I must connect the Mic 2 manually and very annoying. Is there any way, I can rollback to previous firmware. Thanks in advance.
Osmo Action 4 Firmware: 01.04.07.10
Mic 2 Firmware: 04.04.05.13
2024-7-28
Natural Sounds and Sights
You may need to do a factory reset on the mic, then re-link. I have had no issues with mine, btw. Same firmware versions.
2024-7-28
Minh88Vlog
Vietnam
Natural Sounds and Sights Posted at 7-28 23:51
I have removed the battery then put it back after 10s then the problem was solved. The root cause maybe I have connected DJI Mimo app and DJI Mic 2 at the same time.
2024-7-28
DJI Diana
Flight distance : 2408 ft
MinhDevVlog Posted at 7-28 23:59
Hi there,
thank you for reaching out.
We are glad to know that you've found a workaround to this setup.
Should you have any other questions, kindly message us here for assistance. Thank you.
2024-7-29
RDPhoto3
Flight distance : 90686 ft
DJI Diana Posted at 7-29 00:29
Hi there,
I would like to reopen this problem.  I recently did the Firmware Updates for the DJI Mic2 and the Osmo Action 4.  Now the Action 4 will drop the Mic2.  I have had to reconnect frequently today.  I tried a Factory Reset on the Action 4.  It let me reconnect the Mic2.  But later while I was recording it just dropped the Mic2.  Lucky I had Record set to on for the Mic2 and the audio was there.  I have tested this with both my Mic2's.  It is not the Mics unless that firmware is the problem.  I feel there is something going on with the Action 4.  I can't be the only one having a problem.
DJI Mic 2 Firmware: 04.05.01.11
Mic 2 Settings:
Vibration On
Audio to Video Sync On
Low Cut Off
32 Bit Float On
Auto Power Off Off
2024-8-25
