Sean-bumble-bee
Flight distance : 15997 ft
avatalota Posted at 7-30 08:58
Thanks for the response. I have since been using the memory card option- without issue. Its actually nice that DJI gives you a few work arounds for data handling. I will try the DJI assistant route- but would still like to get access to internal memory, at this point, just for the sake of knowing it works the way it should.
"Its actually nice that DJI gives you a few work arounds for data handling. "
I know some people use those alternative methods but, truth be told, I think anything other than removing the card and putting it in a reader is a bit of techy gimmickery or a techy marketing ploy.
I tried the quick transfer thing once with a mini 2 and it was so slow that I stopped it before the first file had been transferred. I haven't been able to get it to work since then lol.
The only time it might be a necessity is if you forgot to refit the card and imagery was recorded on the drone's internal memory. I have had that happen once and from memory had to jump through a few hoops to either get the imagery transferred to the card, or, directly to computer.
I don't remember what I had to do
"I will try the DJI assistant route- but would still like to get access to internal memory, at this point, just for the sake of knowing it works the way it should. "
Understandable, "just for the sake of it" gets us all at times. |
