Waypoint hyperlapse
1020 30 2024-9-27
ChrisOAP
I recorded a hyperlapse waypoint yesterday, it is a 360 degree circle of 19 waypoints, at an altitude of 50m.
Saved it,
Went out this morning to repeat in the dark and when I hit start it said going to first waypoint, then proceeded shoot up to 100m and cancel waypoint ( I've got it set to max height 100m).
Can't edit the hyperlapse waypoints to check settings (like you can withnormal waypoints), so mission aborted, can't do hyperlapse waypoints in the dark.
Anyone else had issues with hyperlapse waypoints?
2024-9-27
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Please refer to the settings here; Waypoint Settings. If issue persist upon trying this settings, please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You
2024-9-29
ChrisOAP
DJI Gamora Posted at 9-29 01:35
Hi there,
Thanks for getting back to me.
The info you've sent is great if doing normal waypoints. I've used this method with great success.
However, my issue is with Hyperlapse waypoints. This works similarly, but in a very limited way, ie you can't adjust any waypoints, only delete them. You cannot see what any of the waypoint settings are at any point. I know in this instance I created the hyperlapse waypoints at 50m above gound and made a circle, followed by saving it. I ran the hyperlink waypoint and it worked fine. The next day I ran it in the dark to create a nightime hyperlapse, but the drone went straight upto 100m an stopped ( my upper limit setting is 100m). If the hyperlapse waypoints worked as normal waypoints I could check the settings.
Thanks for trying to help
Regards
Chris
2024-9-29
Mobilehomer
Flight distance : 18150351 ft
Don't forget this, the drone must be airborne to access Hyperlapse waypoints. I have edited several Hyperlapse waypoint files this way.
2024-9-29
ChrisOAP
Mobilehomer Posted at 9-29 05:38
Thanks for reply, I'd be interested how you edited Hyperlapse waypoints, the only editing of Hyperlapse waypoints I can do is delete each one.
Normal waypoints I can edit in the air or offline, but not Hyperlapse waypoints.
Regards chris
2024-9-29
DJI Gamora
djiuser_7zIi7oWaCEdz Posted at 9-29 03:24
Hi there,
Would you be able to share us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering. We are looking forward to your response for further assistance. Thank You
2024-10-5
ChrisOAP
DJI Gamora Posted at 10-5 04:02
Hi there,
Hi, sorry no video, the hyperlapse didn't start as it cancelled itself when the drone hit my height sealing of 100m. I did another hyperlapse a week ago and ran it in the daytime. I'm going to try it again at night soon. I'll see if it works this time, hopefully it may have been a glitch.
Thanks chris
2024-10-5
ChrisOAP
djiuser_7zIi7oWaCEdz Posted at 10-5 09:07
Thanks chris
Hi tried the hyperlapse waypoint again today.
Created the hyperlaspe waypoint last week and saved it.
Tested it the same day after saving and it worked fine, circling at 50m above ground.
Tried again today, taking off from same position.
Took it up and then loaded hyperlapse waypoint, drone came straight down.. I cancelled at 2m above ground
I tried it first in normal hyperlapse waypoint, ie waypoint 1 to 14, then in reverse, 14 to 1 ( the one I screne recorded)
So something isn't working right on hyperlapse waypoints, after you've saved them and not used for a little while.
Regards chris
2024-10-7
ChrisOAP
Hi there,
Hi, posted a video, but I'm not sure I posted it to you or myself. If you can't see it pls let me know
Cheers chris
2024-10-7
ChrisOAP
Hi there,
Hi, i posted a video a while back, did you see it? Was it of any help.
Regards chris
2024-10-23
DJI Gamora
djiuser_7zIi7oWaCEdz Posted at 10-23 05:10
Regards chris
Hi there,
Thank you very much for your efforts and sorry for the late reply. I'll forward this right away and will make sure to give you updates. I appreciate your patience.
2024-10-24
DJI Gamora
Regards chris
Hi Chris,
Thank you for your patience on this matter, could you confirm if your drone and RC are running on the latest firmware update? If it is not please proceed to update the firmware and if yes, please try to refresh the drone's firmware in DA2.
If issue still persist please provide the requested information below for me to escalate this and check further on this matter.
1) [Drone & RC FW version]
2) [DJI FLY App version]
3) [Flight Log]
4) [DJI FLY App Log]
5) [Date & Time] when this issue happened
2024-10-25
ChrisOAP
DJI Gamora Posted at 10-25 00:04
Hi Chris,
Many thanks for your response.
I thought it was upto date on updates but when I checked I wasn't. So I've now updated the rc and drone.
The rc is now at dji rcs v04.01.0000
The drone is now at 01.00.0700
The dji fly app is now vsn 1.15.0
I went out and created a hyperlapse waypoint, and saved it.
Reloaded it and all ok.
I then turned off the rc and the drone, then turned both back on again.
Reloaded the saved hyperlapse waypoint and it worked great...
So the updates sorted it.
If I may, can i make a request for the developers in that the hyperlapse waypoints be linked to the normal waypoints.
This would allow me to use existing waypoints for hyperlapses and edit them off line.
Many thanks for all your help and understanding, it's still all quite daunting and new flying
a drone, but it's the knowing that there is help available from people like yourself that makes this
new journey fun.
Also I like the new auto focus icon on the front screen of the rc, makes it a lot easier to use.
Many thanks again
Regards chris
2024-10-25
DJI Gamora
djiuser_7zIi7oWaCEdz Posted at 10-25 04:52
That's great to hear. Thank you for keeping us posted. We're glad that the issue is now being isolated. Thank you for your recommendations. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
Thank you for your support and understanding.
2024-10-29
russellg
ChrisOAP Posted at 9-29 09:22
Regards chris
I would also like to edit my hyperlapse waypoints (changing height, drone speed).
2024-12-27
ChrisOAP
DJI Gamora Posted at 10-29 03:12
Hi, just updated again to the latest releases, aircraft firmware 01.00.0800, rc 04.01.0000. Now when I do a rocket quickstep, and it starts to return to the start, the gamble looks upto the sky and stays there. You then have to rotate the gamble back down to continue.
Is this a known bug?
Regards chris
2024-12-29
DJI Natalia
ChrisOAP Posted at 12-29 03:48
Regards chris
Thank you for bringing this to our attention and we apologize for the inconvenience that occurred. Please follow the troubleshooting steps below.
1. For drones without internal storage, check whether a microSD card has been inserted.
2. Check whether the flight mode/remote controller mode is P mode and whether the signal is strong.
3. Check whether the lighting conditions are good and whether there are obstacles around the subject.
4. Check whether the mobile phone is compatible with the DJI GO 4/DJI Fly app.
5.  Refresh the aircraft firmware version and see if it is valid.
Kindly revert if the issue persists. We will provide further help. Thank you!
2024-12-30
ChrisOAP
DJI Natalia Posted at 12-30 01:50
Hi, thanks for this, have checked all that. It worked fine in all quickshot modes until recently, and the only thing ive done is update the rc and mini 4 pro.  It still works fine in mastershots (which includes rocket in the routine). Regards chris
2024-12-30
DJI Natalia
ChrisOAP Posted at 12-30 04:26
Hi there, thank you for the update and we're glad to hear this. Do not hesitate to contact us back if there's any further inquiry.
Thank you for your valued support.
2024-12-30
ChrisOAP
DJI Natalia Posted at 12-30 13:13
Hi, no you misunderstood me, the rocket mode is still not working in quickshots. After doing the rocket video, the gimbol then looks up to the sky as it returns to the start position. It remains looking up to the sky untill you move the gimbol back down.
Regards chris
2024-12-30
DJI Natalia
ChrisOAP Posted at 12-30 14:08
Regards chris
Hi there, we do apologize for the confusion above. may I cofnirm if you've performed gimbal calibration? if not, kindly try perform gimbal calibration and see if that works. You may refer to the linnk shared below for the guidance :
[ https://support.dji.com/help/con ... ;paperDocType=paper }
Thank you.
2024-12-30
ChrisOAP
DJI Natalia Posted at 12-30 15:52
[ https://support.dji.com/help/content?customId=en-us03400006819&spaceId=34&re=US&lang=en&documentType=artical&paperDocType=paper }
Hi, carried out the gimbal calibration and no change. I can't do any more flights for the next few days, the weather is deteriorating with strong winds.
If you have any other suggestions I'll complete them when the weather subsides.
Thx chris
2024-12-31
DJI Natalia
ChrisOAP Posted at 12-31 02:18
Thx chris
Hi there, thank you for the update and we're sorry to hear that the issue still persisst. Could you please share us a video recording of the issue for us to check further on this with our engineering team and advise you accordingly?
2024-12-31
ChrisOAP
DJI Natalia Posted at 2024-12-31 14:44
Hi here is a video of me doing a "quickshot dronie" that works well then a "quickshot rocket:, you will see at the end of the rocket the gimble rotates up to the sky. This is the issue.
Regards chris
1-2 03:57
ChrisOAP
Try again
1-2 03:59
DJI Natalia
Hi there. Thank you for the video. Please refresh your device firmware using DJI Assistant 2 and see if this issue persist. If yes, please provide the required details for further assistance.
App version:
Aircraft Log:
Aircraft version:
DJI Assistant 2: https://www.dji.com/downloads/so ... sumer-drones-series
1-3 01:37
ChrisOAP
DJI Natalia Posted at 1-3 01:37
App version:
Hi, can you send me an idiots guide on how to do all this.
what is the dji assistant 2?
What device am i refreshing using dji assistant 2? The drone or rc.
I down loaded the link to my windows pc, and opened it, the home page just shows a usb cable and arrows which I assume wants me to attach a usb to the PC. I'd did this and connected it to my mini 4 pro and nothing happen, I connected it to my rc and nothing happened.
I looked on my rc while the drone was switched on and it says all software, firmware is up-to-date, no downloads available.
Help!
Regards chris
1-3 02:45
DJI Natalia
ChrisOAP Posted at 1-3 02:45
Hi there. You can download DJI Assistant 2 from the link provided below. Additionally, we have another link for reference on how to use DJI Assistant 2. Please refresh all your devices using the software, and ensure that your device is turned on before refreshing the devices.
Reference link: https://support.dji.com/help/con ... ;paperDocType=paper
1-3 04:06
ChrisOAP
DJI Natalia Posted at 1-3 04:06
DJI Assistant 2: https://www.dji.com/downloads/softwares/dji-assistant-2-consumer-drones-series
Thanks for that,  i found a you tube video showing how it works, I wasn't turning on drone and rc before attaching to pc. I've refreshed mini 4 pro and rc2.
Checked the quickshot rocket and the gimbol still looks upto the sky as it returns to start.
The app vsn is 01.00.800
The aircraft is 04.01.0000
How and where do I find the aircraft log and how do I post that to you
Many thx chris
1-3 04:14
DJI Natalia
ChrisOAP Posted at 1-3 04:14
Hi there, thank youf or the above response. Kindly check the link shared below and refer to the step guidance shared in the link to eport the log files :
{ https://support.dji.com/help/con ... ;paperDocType=paper }
Thank you for your understanding and support.
1-3 07:47
ChrisOAP
DJI Natalia Posted at 1-3 07:47
{ https://support.dji.com/help/content?customId=en-us03400007242&spaceId=34&re=US&lang=en&documentType=artical&paperDocType=paper }
Ok found  log directory, and it's on my PC. Do I just upload it here on this post. looking in the LOG directory and there are 2 directories within, 1 called CASHE and the other RC LOG. Plenty of directories in CASHE but RCLOG directory is empty.
Thxchris
1-3 09:03
