Mavic 3E how does RID broadcast-
301 3 2024-11-13
djiuser_Zg4C2ko2FOn0
Norway
Hello, when testing RID functionallity on M3E, the wifi hotspot it makes is not consistant, sometimes its there sometimes not.
I have not tested if RID is constant when in the air.
How shall this work?
2024-11-13
TonyPHX
Flight distance : 12142077 ft
The Mavic 3E constantly sends RID info.  When it does not, it will let you know that RID is abnormal.  How are you trying to receive it?
2024-11-18
Johnnokomis
Flight distance : 14031719 ft
If you're just scanning for WiFi hotspots to see RID then you're not doing it correctly. By law (US at least) the drone must verify that RID is broadcasting before starting up the motors on every flight. RID is insanely inconsistent even if you're using the proper method for viewing it. It also depends on the manufacturer. Inspired Flight 1200a shows up on the Drone Scanner app constantly. So do DroneTag modules. DJI's are hit and miss and show up sporadically.
2024-11-18
TonyPHX
And android tablets throttle wifi scanning unless you change it in developer settings, and iphones don't even try to let you play ball.
2024-11-19
