pedecytom
Latvia
Quick and dirty of it - can Osmo pocket 3 connected to two DJI Mic 2's record video, and have two separate audio tracks embedded into the video file from each mic????? or can this feature be added?
I have DJI Osmo Pocket 3 creator combo with DJI mic 2. I just Bought another DJI Mic 2.
Main use for the two mics is when doing a travel video or something like that to have good audio for each person and have built in mic audio for ambient audio.
What I liked so far using included DJI mic 2 – the built mic is good in non-windy conditions for ambience, and DJI Mic 2 is just a good mic with the “dead cat” attachment.
For now, when recording a video with one DJI Mic 2 connected, the embedded audio track in the video was from the Mic 2 in Mono, just divided between R / L channels equally, and when I wanted/needed I added the built-in mic audio. Everything was correct length and didn’t have to do any syncing or nothing like that, just adjust the levels or each track.
I’ve bought second Mic 2 so that if I’m filming two people, each can have a mic, for example me and my S.O.
I started testing two DJI mic 2’s connected to the camera and I’ve encountered some problems:
- - The recorded video file doesn’t have two separate audio tracks for each mic, but combines them into one track.
- - Changing mic settings to ‘Mono’ puts that one audio track in the left channel.
- - Changing mic settings to ‘Stereo’ does what it was meant to – recording each mic in its own channel, but still in one audio track.
So, there is no way to adjust each mic level separate from each other…
Actually, there is.
I could delete embedded audio track, and use the Mic 2’s built in storage recording which is mono just divided between R / L channel (just like it was when using one DJI mic 2). The problem with that is it’s not synced/correct length as the video file.
So, for each video clip I have to delete original audio track, connect each Mic 2 to my pc, import both audio tracks, sync both of them, cut them to correct length, then add the built-in mic audio track and then set the levels for each track?
Maybe I’m missing something – some setting or some step in my workflow and somebody can help out with this?
