gimble stuck problem
241 4 2024-12-12
zahidislam
Flight distance : 447743 ft
Bangladesh
sometime drone error show gimble stuck. how solve this issue.
2024-12-12
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
To assist you further, please provide the model of the drone you are using and a screenshot of the error message you have encountered. This information will enable us to better analyze the issue.
Looking forward to your response.
2024-12-13
zahidislam
Bangladesh
DJI Diana Posted at 12-13 20:34
Hi there,
2024-12-13
zahidislam
Bangladesh
zahidislam Posted at 12-13 20:46
[Image]
DJI MINI 2SE
2024-12-13
DJI Diana
Hi there,
Please follow the steps below and see if it can isolate the problem.
1. Please check whether there is debris on the gimbal. If yes, clean off them, restart the drone, and calibrate the gimbal.
2. Please try powering off the drone and move the gimbal gently in every angle with your hand, and check whether there is any debris in the gimbal. If not, power on the drone and calibrate the gimbal.
3. And remove the aircraft’s microSD card and Power on the drone and then calibrate the gimbal.
If the issue persists, kindly let us know!
2024-12-14
