fgange57
Flight distance : 548399 ft
Norway
To get as much time as possible when doing Hyperlapse, I turned off the Obstacle sensing (since the drone should only hover for a long time at the same spot). Annoying to see, the obstacle sensing was turned on when the Hyperlapse started. Another thing was that the Obstacle sensing stayed on after the Hyperlapse was finished.
Next flight the obstacle sensing was off the next two flights and only came on again when I on the third flight turned it manually on again. Is this a behaviour I should expect, or is it an error that the obstacle sensing selected is disregarded when doing Hyperlapse and not revert back to selection after the Hyperlapse?
