DJI Flip front avoidance (ToF) sensor suggestion
156 1 1-18 19:07
djiuser_qUXZL2p1qtUy
Flight distance : 253481 ft
Singapore
I’ve been enjoying my flights with the DJI Flip so far. It has been very easy to use and the camera is so much better than the Neo’s.
In relation to the front obstacle avoidance (ToF) sensor, I would like to suggest that you consider incorporating an algorithm that, when the Flip encounters an obstacle, would instruct the Flip to hover at the stop point and (1) try to fly left by 50cm from the stop point (and forward). If the obstacle is still encountered, then (2) fly back to original stop hover point and to fly right by 50 cm. If obstacle is still encountered, the to fly back to stop point and then (3) fly up or (4) down 50cm respectively.
I suggested 50cm because the Flip is about 30cm in width when unfolded.
I believe incorporating the above would be a better utilisation of the front obstacle avoidance (ToF) sensor.
1-18 19:07
DJI Susan
Hello. Thank you for taking the time to share your suggestions with us. We truly appreciate your input as it helps us to improve our products and services.
The DJI Flip does not have lateral vision sensors, this logic is not quite appropriate. We are always exploring new ways to enhance our technology and user experience, and feedback like yours is invaluable in that process. Please rest assured that your suggestion has been noted and will be kept in mind for future product development discussions.
If you have any more ideas or require further assistance, please do not hesitate to reach out. We are here to help.
1-18 20:35
