iasatan
Flight distance : 15633 ft
Hungary
I am with bigplumbs on this one.
Neo has 2 sensors, the camera and the ir sensor downwards. Indoor you dont have gps, not accurate enough at least. For non military if I remember right outside is half a meter, inside its 5-6 meter. Depending on the module it can be worse.
So inside you have 2 sensors, without light, you have 1. It's trying its best, just like we would when we look at the ground with a binocular in front of out feet. Its impossible to use that.
Since you have the fpv setup, switch it to manual mode, that uses none of the sensors, and only your talent.
Good luck and have fun |
